98TsiAWD
DSM Wiseman
- 2,861
- 8
- May 19, 2002
94 3000GT VR-4,
North Dakota
Ok, here are my mods:
K&N FIPK
1g BOV
Brode Upper IC Pipe
MBC@15psi
Hacked Dump Tube
Sheetmetal Cold Air Box
Greddy Lower IC Pipe
Rewired Fuel Pump
NGK BPR7ES Plugs
Recently launched my car for the 3rd or 4th time since turning the boost up from 13.5 to 15psi.
I drove home about 4 blocks afterwards and when I pulled in the garage noticed smoke rolling out from under my hood, opened it up and found my dipstick had blown up out of the hole, left about a 8 inch circle of oil on the underside of the hood and a little bit on the exhaust manny which was where the smoke was coming from. Cleaned it all off, but still smell burning oil when sitting at stop lights,hmmmmm.
So I start looking around and notice some oil just below my exhaust manny on the pass. side of car, running down onto the block.
Cleaned it all up, started the car, revved it a little to see where the oil was coming out, so far the only place I see it coming out is between the exhaust manny and gasket. Uh-oh. not good
This is either a cracked ring or valve seal correct?
I will be doing a compression check tommorrow morning to see if it is the rings, I REALLY hope its not!!! I'll be
What do you guys think it could be?
K&N FIPK
1g BOV
Brode Upper IC Pipe
MBC@15psi
Hacked Dump Tube
Rewired Fuel Pump
NGK BPR7ES Plugs
