Check out my datalogger cable (homemade)
freshlane
536
13
Sep 4, 2006
Chicago, Illinois
Today & yesterday I was stuck between trying to make my own logger cable and buying one. When it came down to it I didn't want to hand over the cash :). I think I did an okay job on the soldering. The cable works perfect and im happy that now I can see what my car is thinking. Check out the pics and let me know what you think.
ps. I did use electrical tape on the inside to make sure nothing touch eachother.
It would be great if someone (whether it be Digital Tuning or whoever) could come up with a simple install guide where the Palm could be powered by the car itself, instead of using batteries.
I'm sure it's a simple chore of wiring from a low-powered source and making all the right connections, but it still would be helpful to not worry about batteries ever again. (On the other hand, I'm not sure if the info would be saved on the Palm when moving it from the car to the PC and having to detach it from its power source.)
I actually just ordered one. I guess i can use my other car to mess around with power supplies and odbII sensors to see if I get a cable to pull power. I'm pretty sure, it wouldn't be that hard. I just need about two weeks to get it done, and then I can send you a how too, or a cable itself
This is the one things that annoys me about my logger, the damn batteries. Has anyone wired a power source in yet?
update. Just got all the diagrams I need. Just waiting for my logger to come in, should have somthing by next week.
I think you're on to something. And the palm saving the info thing wouldn't be an issue if you just leave a set of batteries in the Palm. You never use them for logging so they'd last a super long time if all they had to do was maintain memory.
So how many would be intrested in actually buying one, at cost plus shipping. I can get a discount on the parts i'd need if I order more then one. I can still do a write up for you do it yourselfers. But after more research, it's not going to be very hard at all.
I'm also designing a cable where we can get power from the car, but I have a few questions.
1. Do you want to charge the Palm in the car.
OR
2. Do you want to run the Palm constantly from the car WITHOUT charging it.
AND
a. Do you want to run power to the device with the constant 12v wire in the car.
OR
b. Do you want to only send power to the car when the car is in ACC or ON.
I'm working with someone who has quite an extensive knowledge about Palm circuitry.
I'll keep you guys updated.
EDIT: Maybe I should make a separate thread for this.
I have put a lot of thought into how this could be done as well. I am not an electronics expert by any measure, but I think this would be highly useful. I have a Palm m515 and it has a "built in" rechargeable battery. It uses a lot of battery quickly if the back light is on at night time... so I think a powered logging cable is definitely in need. I know many people could benefit from this... so someone start spilling the beans.
:mad:
To the OP, good job, making things yourself gives you a good sense of accomplishment. I need to buy some heat shrink tubing too, it will definitely help when I go to wire my ecu harness back together after uninstalling my safc2. blah bla blah...
:mad:
Someone already has. Ask Nate (spyderturbo007) about this discussion. He had someone a few months back make a custom setup so he could leave his Palm in the car at all times and not worry about dieing batteries. (But Nate is keeping it "Top Secret: Eyes Only" for now.)
So you guys are still interested in the powered cables? If the original guy who was going to develop the powered cable doesnt complete it, Ill go ahead and do it.
Id be interested to find out if all Palms use the same voltage batteries.
Always giving me crap, aren't you, Anthony. :D
I asked him if he wanted me to make it public, but haven't received a response yet. So I don't want to go throwing his information around until he gives me the "go ahead". Besides, I haven't gotten it yet and there was a slight problem with the build.
Apparently there was a miscommunication about the battery situation in my Palm. I guess I led him to believe that my Palm used AAA batteries when it doesn't. :coy: So when he got my palm and saw that it was an internal rechargable, that was a problem. He said he is going to redesign something for me so that it will work.
Either way, I promise you'll be the first to know if he wants me to make it public. ;)
Here's a pic of it. Sorry about the quality, I took it with a cheap camera.
It actually looks like the cable was built correctly. The quality could have been a bit better and you could have made it more compact, but thats fine. You are using a palm serial cable right? You said that mmCd doesn't connect?
As far as the charging in the car thing goes, I was researching it and found a thread that someone stated that they have that set-up in their car now. It mentioned using a Y sync cable that has both serial and USB plugs on one end. Serial does not provide for charging, but USB does. Just use the serial plug for your logger and run 3v(mighty be 5v...gotta check my Palm) through the USB for power. I have a cable on the way now to try this with my M130....just gotta hit up Radio Shack for some goodies to step the voltage down. I'll update once I get it done.
Here's the thread....third post from end is the one I speak of.
http://www.dsmtuners.com/forums/showthread.php?t=243776&highlight=logger+geeks
Yeah i can not get it to sync on my buddy's car but he totaled so now i have to get my head put back on i love jumping timing....not
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
