PieEyedPiper
DSM Wiseman
- 5,580
- 65
- Nov 13, 2004
North Bay Area,
California
I've had this problem for a while now. It all started after I had a v8 shop do my clutch job
barf: ).
When taking off even under light throttle my car will clunk or click really loud, once, and then carry on its merry way. This also occurs when under acceleration.
So it happens when:
i.e. Starting from a stop sign, going up my driveway or giving it some gas in 2nd to scoot around town, when turning when going straight etc..
The sound is quite loud and I can feel it through the entire car. Seems like it is coming from the passenger side but its all subjective.
I've changed the fluid in my rear end and transfer case. Both oils came out relatively clean and there were no metal chunks, hardly any glitter even. I would like to cross these off my list as the possible culprit because my transfer case showed no signs of wear and moved quite freely when turn it by hand (I removed the unit today for inspection). And the rear end seemed good too - plus the sound isn't coming from behind me.
Unless someone can give me some more suggestions I think I've narrowed it down to my transmission/clutch/center diff or my axles.
The funny thing about my axles is that I yanked on all of 'em real good today when the car was jacked up and not one has any play or movement whatsoever. Nor were any of the boots torn.
I'm poor and frustrated, can anyone give me some ideas?
barf: ).When taking off even under light throttle my car will clunk or click really loud, once, and then carry on its merry way. This also occurs when under acceleration.
So it happens when:
