Need a basic ground tune for:
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
Could someone point me in the right direction with helping me tune my car? My mods are: 550cc injectors, td06h 20g, SAFCII, injen intake, 28x10x3.5 fmic, and 3" turboback exhaust. My car is running extremely crappy right now so I was wanting to get a decent base tune to even it out a little bit so that I could drive it and not worry about it running way lean or way rich until I can get my 255lph, fpr, and then get it tuned on the dyno.
Every car is different and the same tune will not usually work on seperate cars. With this in mind the only real thing you can do is buy or borrow a fellow DSMers ODB-II pocketlogger and go from there. There is a great tuning guid found in thech articals under tuning found here: http://www.dsmtuners.com/forums/showthread.php?t=58403 . I am sure there are other dsmers in your area that may let you borrow the pocketlogger. I usually lend mine out to others in exhcnage for a dinner at some fast food place. Unfortantly the RRE site does not give SUGGESTIONS on anything close to your setup. But the do stress the point that every car is different: http://www.roadraceengineering.com/newafcsetting.htm
