What's a G6 head?...never heard of a code for heads.
insanewayne
317
May 18, 2004
Ladysmith,
Hey...I actually heard a DSM part I didn't know about...I thought the heads were just 1g heads and 2g heads...whats a G6 head? You can't search for 2 letter words in here (which sucks sometimes), so I couldn't find anythig about it. Is it just the head with the biggest ports or something?
Thanks
Wayne
Naw I read a guy's post on BCDSM sayin that he checked his head and it's a G6, and another guy sayin that it'd be sweet if a certain 6/4 bolt combo had a G6 head as well, so I dont think that's it, but thanks.
Wayne
Those are casting numbers on the head itself...
The later 7 Bolt heads share these same casting numbers (G6/15, G6/5). According to RRE, these are the "Preferred" 1st to 2nd gen heads for swapping.
Major differences are the 11mm head studs on the later 1G 7 Bolt, vs the early 1G 6 Bolts's 12mm bolts, 2 larger 10mm exhaust manifold studs, and better cooling characteristics of the later heads. -To quote RRE, see this...
http://www.roadraceengineering.com/1g2gheadswaptechtip.htm
This is a pic of my old dead head off of my 94 TSi AWD...
That's great guys thanks alot - Where would I find this stamped on the head?
Thanks
Wayne
Thanks
Wayne
-Right above the coolant/thermostat housing, between the cams (for the pic in my previous post). The other casting numbers for the head's version can be found under the oil diverter valve that supplys oil to both cam's oil feed passages for the lifters & rollers (under valve cover, See Pic). From my experience, I've seen mostly the M5 or M4 versions were in the 1st gen 7 bolt motors.
