Ok I have the exact same car, and had the same exact issue, since you blew your turbo and have a new one in, do a boost leak test. Ok start it does it do the same thing? if it does then check the screw right on the throttle body, it will be philips screw. Srew it in or out this will +/- RPM cant miss it right above TPS (throtle position sensor) did that work? if not then read this,
Is my tps toast? 4.6@pins1,4 and 3.8@pins 2,4
There is alot of knowledge about Tps. The problem with my was it started at 1500rpm then went up to 2000rpm once I fixed my manifold crack and boost leaks, then I turned the scew on my throttle body and it was perfect!!! good luck!
