awild
- 401
- Jul 28, 2003
Grand Rapids,
Michigan
So I was thinking that maybe I had a valve cover gasket leak. Not looking so likely anymore. I went out to check everything this morning and saw not only oil but some coolant on my trans:thumbdown . So I started the car, looked under the hood and smoke was coming out from [under] the turbo.
Side note - (Car is not driven all that much lately). First time I noticed this the blue oil smoke was coming out of my hood and the engine temp was way up. I still think it could be the valve cover gasket because there is a lot of oil on the pass. side of the engine, but also coolant over there. Why would this make the turbo smoke? Maybe it blew oil onto the turbo and it was just burning off what was on the outside?
My guesses:
Bad Turbo
Valve Cover Gasket
Blown Head Gasket
Stuck Valve Stems
Can you help?
My guesses:
Bad Turbo
Valve Cover Gasket
Blown Head Gasket
Stuck Valve Stems
Can you help?
