help after denso 720 install
akdsm
59
Jan 4, 2003
Chugiak, Alaska
ok im not sure if this is in the right spot but just hear me out...
i just changed my rc550 injectors for denso 720's and my car runs horribly!! its ok at cruise and idle but when i try to accelerate the car starts to studder,bogging(misfire?) and egts go out the roof....i have no knock, but my timing at wot is 7-8 degrees which as i understand is pretty damn low................my global is-38 and deadtime is 420, my ltft is fine around 2. have no idea whats going on checked all connections in the engine bay everything is fine could it be faulty injectors???
really need help thanx for the input..........
Ben
Not really sure why you're getting big problems, but the DSMLinkv2 user guide says that dead time for a set of denso 720s should be close to 450.
Of course if your long term fuel trims are looking good then you might be fine on that note.
-T
we made it to compensate and it still took a crap on me
i put the 550 injectors in andeverything ran good except my injector duty 107%:( but anyway what do you think?? injectors are bad?
