boosting1G
- Feb 26, 2003
Okay here is the ordeal. my water pump was going out about 2 weeks ago. It was making a nasty grinding noise. I decided to change the pump before it got to bad. I installed the new water pump and the new gasket. after ecerything was done and back together I start the car. after about 6 minutes there is steam and water everywhere. I know I torqued it right and installed it right. I remove the new pump off of my car and the new gasket literally desolves in my hand. so I figured I just popped the gasket. I tried putting form-a-gasket on it and reinstalled it. Done YET AGAIN I start the car after about 3 minutes water is dripping below my crank (from pump or coolant returnline) I seal off the returnline with form-a-gasket to see it that is where it was leaking. star the car again. IT STILL LEAKS!!! I am about insame now. this is my second motor I just put it in about 2000 miles ago had the tranny rebuilt and various other things done. 6,000 bucks later and I am broke and I am stuck with this broken car. Any help?
