r0n
- May 9, 2003
California
I lost my brakes and checked it out. I found a small leak were the brake line attaches to the abs unit on the right side. I have a 2.25 upip and the bov is facing downwards near the abs unit. The bov is was hitting against the line and finally bent it enough to make it leak. I unscrewed the line for the abs unit and as I was sliding the part that screw into the abs, the line broke. No force it just broke easily.
This line goes all the way to the MC. Is there any fix beside replacing the line? It looks like a lot of work just to replace that line.
, I couldn't think the right tool name. I just happen to have these tools when I was doing my fuel lines my 71 240z. I didn't do a double flare... for one I didn't know, second it flared to much so I had to file it down a little which made the end thicker. Hopefully that was good enough.
