Eclipsed
- 2,581
- 26
- Aug 14, 2002
Chicago,
Illinois
I purchased a 95 gsx with a 6 bolt swap in it from a reputable shop a while back. Ever since I got the car the radiator light (carnival light), battary, and handbrake light keep coming on. They dont stay on constantly but fade on and off, but just the other day they were on for a while. I asked the guy I got it from and he says that it started doing that after he put the new flydine radiator on and called the shop that did the swap and they said if nothing is leaking or anything is really happening then it will be fine. This happens occasionally. Has anyone else heard of this?
My question is, could it be because of a problem with the clutch? BECAUSE I had a 95 vr4 a while back and when you kept the clutch pedal in to long while moving, those exact same lights would come on. Same as this car. It has a 2600 in it and a b and m shoft shifter. Could the trans mods be causing this somehow or just a short somewhere?
