GT40MkI
- 40
- Jul 8, 2003
I've searched...
If this leads to a repost I apologise...
After being down with th 2.4 conversion for about a month, it was all completed about a week ago. (2.4 came from a running car with no known issues other than some lifter noise that is still apparent.) Car ran fine for about 15-20 miles of cruising last night. Tonight I rolled into the throttle to see how it felt and after a loud pop from the rear (exhaust?) the car resorted to barely running, I had to drive with "three feet" to keep it alive...
Symptoms:
*Car will rev fine if throttle is mashed as the starter is turned...
*Once the car has idled for a few second, you can go WOT and the car runs to 2k rpm like its hitting a msd style rev limiter..
*Idle is erradic and stumbles around 650-850rpm, going back and forth from turning off and barely running.
*Oil is fine( no water, fresh mobil 1 20-50, good pressure, none lost).
*Coolant is clean(no oil...)
*At idle, I only see 8-10" of vac instead of the usual 20ish..I know this could be caused by a number of things..
Coil pack?
CAS?
Anyone have experience with this?
Thanks in advance, tomorrow I'll do the usual-
Check plugs for fuel/oil and double check the gap..
Compression Check
Double check base timing
Check intercooler piping for leaks.
Symptoms:
Coil pack?
CAS?
Compression Check
