boostineclipse
- 180
- May 19, 2002
Sacramento,
California
Ok..it seems I am not getting any fuel to the engine. I loosened the top line on the fuel filter a bit and put the key to both the on, and tried to start it up..each time no fuel leaked out.
I hooked a jumper from the postive bat terminal to the fuel pump check connector in the engine and fuel started commin out of the top filter line.
Bad fuel pump relay maybe? Or a connection got severed that operates that relay from the ignition point?
