NPCTNUSA
- 31
- Jul 18, 2003
I CURRENTLY TRIED INSTALLING A PUSH BUTTON STARTER I BOUGHT THE WIRING DIAGRAM AND ASKED FOR THE WIRES FOR THAT AND I WAS TOLD THE CONSTANT POWER WIRE SOLDER A WIRE FROM THAT AND FASTEN IT TO THE BUTTON AND ATTACH A WIRE FROM THE BUTTON AND GROUND IT SO I DID I PUSHED THE BUTTON AND IT BLEW THE STARTER MOTOR FUSE SO I SWITCHED THE WIRING AROUND THINKING THAT I PUT THE HOT SIDE ON THE GROUND AND VICE VERSA AND TRIED USING THE KEY THIS TIME AND NOTHING HAPPENED IT TURNS TO ACC AND THEY ALL COME ON BUT WONT START I TESTED ALL THE FUSES AND STUFF UNDER THE DASH THERE AND IN THE POWER DISTRIBUTION BOX I TESTED THE STARTER RELAY AND CHECK THE BATTERY WITH THAT BOX WITH JUMPER CABLES AND TOLD ME 12 VOLTS SO THAT ALL CHECKS OUT IDK IF THERE IS SOMETHING ELSE TO CHECK ON THE BATTERY OR NOT BUT WHEN I TURN THE KEY TO START NOTHING HAPPENS AND WHEN IT CLICKS BACK OVER TO ACC IT CLICKS THREE TIMES OR SO UNDER THE HOOD ON THE DRIVERS SIDE, AND ALSO WHEN I PUT THE BATTER ON A BATTERY CHARGER OR STARTER THE LIGHTS DIM WITH THE HUMMING OF THE CHARGER AND MY GAUGE READS 12 WHICH IT USUALLY READS 14 JUST TRYING TO GET ALL THE INFO OUT THERE CAUSE I REALLY NEED HELP PLEASE SOMEBODY TELL ME WHATS GOING ON HERE
