reclise93
- 69
- Aug 9, 2002
ok, this car broke a balance shaft belt a while back, causing the timing belt to jump timing,,,,so i figured the knock was bent valves, so i pulled the head, all looked ok both with head and block but i sent the block to the machine shop anyways, had new valve seals put in since they were shot,,,but they said the valves were all ok, now i put it back on, put the belts back on, and without the plugs in,,,as in no compression all sounds ok, no knock or anything thats not normal at all, , but when i put the plugs in, it knocks, ive also pulled all but one to see if it was just from compression in one cylinder but if i put one plug in each cylinder on its own each one still makes the same knock sound when i turn the motor over,,i dont get it, when the balance shaft belt broke it only make the t belt skip a couple teeth,,,so i never lost oil pressure,,any ideas?
