bigroy_80
- 55
- Dec 11, 2003
Front Royal,
Virginia
ok well when i bought my talon that owner before had one of the big 5" or whatever after market tachs in it, im not much for it when u have a perfectly good one in your instrument panel. well anyways i just got a boost gauge and pillar gauge pod and to mount the pod i needed to remove the big tach so it gave me reason to take it apart and get it off. well i get everything off and then i pull my gauge cluster off, the whole thing as in clear plastic front cover to back circuit board. he had it hooked up using the screws on the back of the circuit board. well i get it out and remove all wires that were connected to the after market tach. well i get this done and put the cluster back into the dash, btw i did not take apart the cluster in anyway just removed it from the dash.well i start the car and i find that the only gauge that works is my speedometer. all other gauges do not move. i tried to do a search but could not find the right keyword to find what i needed. well i was wondering if anybody knew how it was supposed to be connected, if any of the wires on the back needed to be connected to anything. just what i need to do to have my instrument panel working again.
one more question....when i start my car my as i start driving it makes a squeaking sound as i get faster it gets louder and faster. my dad said that he thinks the speedometer needs oil. well if this is it how do i go about this if this is something else what do i need to do to fix it.
sorry for this being so long i just want to make sure i have all the details that i can think of if you need to know something else to help let me know and ill inform you of it.
many thanks in advance if you can help
Roy
Roy
