Gno1316
- 52
- Jun 22, 2002
New Jersey
Ok, im installinga wiring kit for my amp so i had to disconnect the positive cables. I took a nut off then the 2 wires that each have "O" connecters. Then took off another nut to take off the "main" cable.
I put it back together in reverse order and even cleaned the connections with a wire brush. But now when im sitting there idling I idle at 100-200 rpms. Not 1 - 2 thousand, 1 - 2 hundread. Is the low idle caused by bad connections? Or does the car need to readjust since i disconnected the positive cables?
