need some help AGAIN guys
siceclipse
1,681
12
Jun 26, 2003
FFLD County, Connecticut
sorry to be annoying like this but the last time i posted here i was complaining of no boost in first. well i let my friend take it out really fast and when he came back i was like, "Well? what happened?". he said "oh sorry i took so long i stopped to fix the problem." the problem was that i was boosting so high and so fast with the t-25 i blew a vac line off the intake. well last night i was out playing again, and i did a 3500 rpm take off with the stock clutch and i think i heard a small POP. and now i cant boost in first again. i already checked all the hoses and they are all attached.
anyone wanna take a stab at this?
ok, if I was in your shoes, I wouldn't just look around the turbo. Look at the vacume lines where your pressure sensor is. Or check that to see the factor boost controler is pluged in correctly. Maybe your friend switched the lines...who know. and also do what was mentioned before
tell me if you get her to boost
im at work right now so ill have to do this later tonight in the dark god help me, but ill tell you guys whats up tomarrow.
thanks for the responses
