Check Engine Light
Originally posted by Eclipsionz23
need info on what an evap emission control leak would be PLEASE!!!!
Thanx! theres probably too many vac lines to tell where it could be though, huh? -neWb
Originally posted by Cablefed
Bad Vac. line in your emissions loop. Hunt it down and replace it.
Did some lookin into the problem....I found that it could be several things: EVAP purge solenoid; Clogged Purge Line; Vacuum hose as you said; or the EVAP emission canister is clogged. KNow anything about these that i listed and what the cost might be???
