What would you do??? Electrical, short and precise
zachab242
78
May 10, 2003
92' Laser 1.8 manual........
My CURRENT problem(LOL):
1) I have no spark
2) windshield wipers dont work
3)turnsignals dont work
But the engine does try to turn over........
Ive replaced the distributor, alternator, ECU, and the battery!
My question is, what would you reccomend i try next?
And NO I will not get it towed to the graveyard! ALL you LASER haters..........LOL
I know you have probably tryed this but have you checked all fuse boxes? Also, did all this happen at once or is this just a build up of problems over time? What mods have been done to the car recently?
It actually began before i replaced my head gasket, the car would stall and then one day it overheated... so i replaced the HG and had the head machined and leak tested... but after i put it all back to gether i had electrical probs.... which turned out to be a dead battery..... but now the Window wipers and turn signal doesnt work...i did replace the power transistor i believe its 80amp In the engine bay passenger side.... Im certain i hooked it back right, but maybe not, I have the rounded off Lead on the transisitor cloosest the firewall and the squared closest the headlights.....
