mattn
- 128
- Jul 24, 2002
I blew the T-25 and just recently installed a 14B on my car.... it's still puffing blue smoke from when the T25 went out, theres still quite a bit of oil in the exhaust from when the oil seals on my old turbo blew..
Anyways, today I installed the oil feed line and actuator...
Take it for a test drive and the result is:
- No boost in neutral. (10 Vac)
- No boost when driving - will not go past 10 Vac
- A/F gauge reads fine. Not too rich and not too lean, right where it has always been.
Now I know the turbo is in perfect shape. No shaft play whatsoever. Does anyone have any suggestions as to what the problem could be? When my T25 was on its way out, I removed some of the washers from my Turbo XS RFL bov so it would build a little boost.. Perhaps I should put some back in? I only have one in there at the moment... any suggestions would be greatly appreciated!! I'm going nuts.. my car has been down for almost 3 months now.... 1st the engine, then the trans, and now the turbo... im dying to get this thing running!! please help!
Thanks,
Matt
Thanks,
Matt
