m[ohio]
- Jun 20, 2003
I've been searching for a few hours now both here and on DSMTalk and have found no real solid answers on what is causing my hard start problem on my 2G. When it's cold out out the car will usually start right up on the first try, but when the car was run recently or when it's really warm outside it cranks like crazy and won't start for about 15-20 seconds of cranking. Then it catches and idles rough for about 10 seconds and after that runs PERFECT. No idle issues, no surging or hesistating when driving. I've got a datalogger and have checked for CEL's and so far none have popped up. Any suggestions? I was thinking the coolant temp sensor or wire but I checked and the connection looks good. Is there any way to test to see if it is in spec?
Thanks!
Thanks!
