quickersol
- 128
- 10
- Oct 25, 2002
i finally got the at to mt swap done and have sorted out most of the bugs. the car runs and drives ok but when the clutch pedal is released the car makes a clunk type noise (persistant when the pedal is released) it sounds like the flywheel or something similar is coming in contact with something. when the clutch pedal is depressed the noise goes away. you can hear it when driving and also when in neutral with the clutch released. should i adjust the pedal linkage or pedal stops? any other ideas?
im so car stupid....
