Replaced Crank Pulley, have a big problem...
In2Deep522
Aug 31, 2002
Philadelphia,
Hey everyone, here is my situation withj my 97 GSX. Last week, I noticed my belts were screaming and I started hearing some metal grinding and some tapping noise. I check out the car and it seems that my crank pulley has gone bad and separated from the harmonic damper and was clashing with the frame and that was causing the noise. Well, after I found out what the problem was, I started up my car once again to put it in the garage when all of a sudden I hear a loud ass humming/ rubbing noise and hurried and turned the car off. Here, the accessory belts had come loose and the crank pulley was nearing hangin off. The next day I went to Mitsu and bought the OEM crank pulley and new accessory belts. I removed the old crank pulley, replaced it, and replaced the belts and thought everything went nice and smoothly. I started up the car and I hear the same damn humming/rubbing noise as I did when the car first went out of commission. I wasn't sure what it was so I figured I would take everything apart again (crank pulley and belts) and check the timing belt cover to see if there was any rubbing from the crank pulley or belts. Well, with everything apart, I could not find anything at all. So I decided to check the timing to make sure nothing inside the engine was f*cked. It seems that my timing is right on. The two notches on the cam gears line up and the crank pulley notch is just a c*nt hair below the T notch on the timing gauge thingy located on the TB cover. Well, it seems that the timing is ok and my internals are not out of whack....what could this be?!??!!? Like I said before, when I start up my car with the new crank pulley and belts on, I hear a really loud rubbing/ screeching noise. I have no clue what it is or where to start looking. I was sure to find something when I took apart everything but found nothing. Does anyone have any direction for me? Any help is appreciated! Thanks and hope to hear from you soon!!!!!
Justin
Well, nevermind everyone, I fixed it. I took everything apart and cleaned everything really well. I went through a process of elimination and fixed the problem. I first ran the car for 30 seconds with the crank pulley and belts off to see if it was them or a separate problem. When I ran the car, no noise was heard. This told me that is had to be either the crank pulley or the belts. Next, I installed just the crank pulley and ran the car for another 30 seconds...still no noise. Next I replaced the A/C belt (tightening to spec) and no noise once again. Finally I installed the Alt belt to see if it was the water pump or power steering pump or belt and no noise once again. Well, I must have had one of the belts out of spec but now everything runs perfect....just figured I would type this up just in case anyone else comes across this problem. See ya!
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
