jjbrasil
- 143
- Apr 1, 2003
Northville,
Michigan
ok i was finished on an engine swap on my car and my freind was over and he accidentaly sparked the bottem wire goin to the alt for a second...and i tried to fire her up and wouldnt....so i checked and im getting spark in all cylinders, compression is fine, I took a tiny bit of gas, put it down the cylinder and when i tried starting it, the car almost started...so im not getting any fuel. I then checked to here if my fuel pump was turning on when i keyed on and NO the fuel pump is not turning on. So i checked the MPI fuse and that seems to be fine, the EFI relay clicks when i key off so im assuming its working but when i ohm tested it from what the manual said to do 4 different patterns off the leads...and i only got 2 out of 4 to give me power..i dunno if i was doin it wrong maybe but who knows, i also took the pump out and tested it and it worked fine when it had a direct connection to the battery... is there any thing i can check that can maybe help me out..and suggestions would help a ton.....thanks for your time
