Lordpaxin
- 1,890
- 15
- Apr 21, 2003
Jackson County,
West Virginia
background:
1991 tsi awd JDM swap, aswell as MT swap.
everything works fine, engine will boost strong to 9-10 psi at 2200rpm
during throttle there is no hesitation or inconsistancys in rpm, or engine functions.
When you first start the engine. idle hangs around 2200 rpm and is rock steady.
once engine reaches temperature, idle begins to surge anywhre from 1000 - 2000 rpm.
while driving down the road, and you let off the throttle, engine will surge, buck kind of, like if you would be decellerating in gear, and tap the gas gently (indicating the surging)
my ISC is good, dunno about the PIAV, or whatever its called.
I know my base timing is slightly off, but it isimpossible to correct that, while my idle is gorilla cocked.
did a boost leak test, and i cannot find anything, NO check engine lights, no nothing, except sometimes, my coolant light (birdcage) will light up, and go off again.
making me think the temperatre sensor may be bad, and the engine doesnt know if it is warmed up or not, or the signal from the sensor is oscillating, and making the engine go in and out of warmup repeatedly.
any ideas. will be super cool.
also, on the thermostat, there is 2 places to plug in the small wire. one of front, and one or back. dunno if thre is any bearing.
thanks, adam, sorry for the longpost.
