Dash lights don't work???
CBgst
582
Jun 25, 2002
I've got a 92 awd laser. I bought the car like it is so I don't how or when they quit working but my dash lights and the power windows don't work. I couldn't find a fuse for the interior lights so I just checked them all. There is one missing but it's for the alarm( one of those big square ones). Any ideas would be great.
what did you use to check the fuses? does the car run? Did you check the Fuse inside, and under the hood? A Fuse can Blow, and cant See it. its happen to me a couple times. sometimes when people try to install a head unit, they will let the power wire Ground, and that can blow some fuses. not just one.
The car does run. I checked the fuses you can see. I really don't know how to check the sqaure ones you can't see through. I was hoping someone might know where that particular fuse was but I guess I just need to change them all if I'm not sure if it's burnt.
get a Test Light, There REALLY cheep, And you wont have to pull out the fuse. theres a Small slit on the top where you put ur Tip on, and it will light if it is good, Or it wont if it is blown.
