My turbo.. need help
prodsm
258
Nov 12, 2002
canada,
i have a 90 tsi awd,
i took of my intake tubing to check for shaft play, to see if my turbo was on its last leg. When i checked there was NO shaft play at all, and a very small trace of oil. Is there anything wrong with my 14b?
My car burns a little oil, so i thought it was the turbo, now i dont kno what to think...
any ideas?
:talon:
Originally posted by GoSpeedRacerGo
How much smoke comes out of the tail pipe? Is it on startup or all the time? Is it white/grey/blue? Need some more info.
a small amount of blue smoke, when i rev my engine, the smoke appears most when i start in first gear...
Did you pull on the shaft also to see if there is any in and out play. The oil could be coming from your valve cover vent tube, the one that goes into the intake. check inside your intake tube to see if there is any oil in it. If there is I would check the pcv valve just some thingss to check.
Tyler
Tyler
My PCV valve is fine, b/c i just recently replaced it, when i checked my intake there was only a small amount of oil in it and a small amount in my turbo.
Could the seals be wearing out resulting in oil burning?
Im pretty sure the seals in the Turbo are worn out. B/c when i looked into the turbo, there was a small amount of oil in it aswell as some in the intake pipe. However there is no shaftplay....
Im confused, i think its the turbo and not the valve seals..
but im sure... WTF should i dooooo
If i do a compression test how much PSI should i be getting per cylender?
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
