skifreee911
- 29
- Jun 8, 2002
Knoxville,
I just replaced the passenger window motor and the window switch. When i first put the new switch in and pressed the button it went down about and inch. now the only way i can get it to go up and down is if i wire it directly to a power source like the battery. What am i overlooking that can cause this to happen. The driver side window works perfectly. it was doing the same thing with the old switch. I thought the driver side and passenger side had the same fuse. When i hook up my multimeter, when the switch is pressed it gives out 11 or 12 volts.
