dsm1gturbotalon
- Jan 1, 2003
Racine,
Wisconsin
I had my water pump and timing belt replaced three weeks ago. I live in the dorms at UW-Green Bay and was on my way to Racine to visit the family when the water pump gave out and the car started to overheat. I pulled over and had it towed to the nearest AAA certified shop. I picked the car up a few days later and didn't have any problems until this past Sunday when I was backing out of the garage. I noticed a squeaking that I hadn't heard before. I shut off the car and took a look. I noticed the alternator belt was frayed on the side towards the engine. I then found the other part of the alternator belt laying down there. Apparently the AC compressor belt had come off it's pulley and lodged itself behind another pulley. So I decided to take the AC belt off(bad idea?) because my AC doesn't work anyway(needs recharging). The car was started again and it was making some noises. We noticed more belt fragments coming off under the car. We let it run awhile and figured it was the remnants of the ac belt that had become stuck. I then made my way up to Green Bay which is about 150 miles or so. I made it within 10 miles of Green Bay when it sounded like the cruise disengaged and then I put the clutch in and the car died. I pulled over an had it towed to the university. I went to look at it this morning and I noticed what looks to be an exit hole on the timing belt cover. Did my timing belt jump? If so the motor may be gone right? I called the shop and they are coming probably today to pick the car up. They have a 1 year warranty on their work so hopefully there won't be any trouble if it needs a lot of work. I'm just wondering what the possible problems that could have occured?
I'm just glad that the car is getting out of that shit-hole. I didn't allow them to remove the head so all I know right now is all 16 valves are messed up. They still claim the pistons should be fine. Amazing....
