nolimits
- 61
- Jul 11, 2003
I decided to replace the electrolytic capacitors that are known to go bad in the 1G ECU's, and I find that a previous owner has that entire area submerged in gray RTV sealant. Would this be an effective fix? I'm assuming it was just a preventative effort since everything works fine. It's on there pretty good so i figured I'd just leave it (rather than risk doing more damage from trying to remove it), I just wanted to see if anyone has heard of using this method.
