Throttle body question........
BoostedBird
192
May 20, 2002
Milwaukee, Wisconsin
I was doing the VFAQ leak test and I can heard air leaking near the throttle body. When I looked closer, I saw that on top of the throttle body, there are 3 fittings were hoses could come in. Labeled P E A. They appear to have a ball bearing looking fitting in each of the tops of them. Well at least the E and A fitting do. My P fitting is completely empty. No hose coming in or ball bearing "block" on top. Is this right? Am I missing a vacuum line? Could this be the cause of my not being able to boost past 9 PSI? Any help is appreciated.
Your not missing anything, my "p" is also empty and does not have a vac line.
Thanks for the replies. I did a pressure check last night and sprayed soapy water on there and nothing so I figured I was OK. But I was getting a leak some where by the throttle body. Sprayed all around it and couldn't find it. I heard something about rubber seals on the throttle linkage or something. Anyone know any leak possibilities around there or heard of this? :confused:
Don't know if it is between the TB and the manifold or the elbow and the TB. I sprayed everywhere. Didn't see any bubbles. Seems like it is from the back of the TB. Ordering new seals just in case. Will see what that does.
