redslush
- Sep 3, 2003
I am trying to trouble my starting problems. I get in the car today and it smells like a dirty whore house
I took the ecu out and it smells bad.
Before taking it out I check the power getting to the efi relay and there was no voltage reading. My question is, would a bad ecu cause the efi relay not to get any power. I also check the Fuel Pump connector and no voltage there as well
I took the ecu out and it smells bad. Before taking it out I check the power getting to the efi relay and there was no voltage reading. My question is, would a bad ecu cause the efi relay not to get any power. I also check the Fuel Pump connector and no voltage there as well
