Question about Oil and Breakes
Chris95GST
224
Aug 12, 2003
Hi, I have a 1995 GST and I just changed over to synthetic oil and I noticed that while I am stopped or at idle I have very low oil pressure. As soon as I start going though it goes back to the middle in the gauge. Is this normal? Also when ever I break from 70mph or higher my wheel shakes. Thanks for any help.
check your oil level, if its low then the pressure can drop some.
for your brakes, the rotors are probly warped. same thing happened to me too. just get a new pair.
Thanks :thumb: Hey I have two questions I always have this sort wierd wine while driving but when i turn on my blinker the wine gets lounder and goes to the rythem of the blinker. I also have this wierd tapish noise that happens when i let off the gas and my revs go down to around 2k rpms. It seems to becoming from the right side of the car as well and it seems to be coming from the engine compartment. It sounds kind of like big rain drops falling on metal. Oh and the clutch pedal kind of moves a vert small amount. The noise only happens when the clutch is not pressed in though. Thanks agian for any help.
