Cw
talongod
274
Nov 24, 2002
Mayfield Hts., Ohio
My door sticker says 4/94 but its a 95 tsi i have over 120k miles on my car and the clutch started acting up and my car stalled out and wont start up im getting no spark and i took it to my mechanic and he said its a crank shaft sensor HELP do u think this is CW? what should i do?
OK im pretty sure i have crank walk i was just wondering cant you get new main thrust bearing or even a crank would that fix or help out and would it cost less than a block i just need it to run until winter
Yes... you can get new thrust bearings but it depends on how chewed up your crank is. You will also stand the chance of it happening again, if indeed you can put new thrust bearings back in. It could last another 120,000 miles or it could last 100 miles. I have asked about it at my local dealership and they told me that they would have to drop the oil pan first to make sure. They quoted me roughly $800 bucks including labor for the replacement.
