Thunderskull
- 469
- Dec 10, 2002
Long Beach,
California
Ok, this is a wacky deal that I'm having with the car. Being new to suspension and steering work, I need some help. So, I'll start from the beginning.
My alignment was all wacky, and I was going through tires. I noticed my tie rod ends were destroyed. The boots were completely ripped apart. So, I replaced the tie rod ends myself. Which BTW is a real PITA even with a tie rod end seperator. Shortly after a tire blew. I couldn't get a used tire for my car because the 2 places I went to didn't have em so I had to get new tires on the front. I got the cheapest ones which were about $130 installed. I waited too long to get an alignment and the inner tread on my front tires are worn. (the place I went to said the camber was fine but my toe was all screwed up) In the meantime I repalced my brake pads and my front right caliper which had seized. I then went and got an alignment. The car does drive much better than before.
However, the car still wants to pull to the right a little. When I gun it, it wants to pull to the right a lot. It also wants to pull to the right a lot when I brake. Now, when I downshift, it wants to pull to the left. I'M CONFUSED!!!!! Now, when I turn the wheel on my left front, the brake pads don't grind on the rotor. They do on the right front. Please help me! Do I need new tires, or do I need to go back and check my brake work. Could it even be something else? I don't want to throw parts at this.
Thanks!
Thanks!
I'm probably going for new front tires at the same time. The inner wear is really bad. It's almost completely worn down.
