evil_eagle
- 597
- 17
- Dec 19, 2002
Nampa,
Idaho
Allright, never thought I would have to ask for help, but I am stumped.
The problem started about 2 months ago and to this day I have not been able to figure it out. Heres the deal, as a consistent weekend drag racer at the tracks I change my plugs often, 2 month ago I notice when I pulled the plugs that there was fluid on the threads of the plugs, not oil, not fuel, and does not have any smell to it, just like water, so I thought the head gasket was gone, did a compression test on the motor (3000 miles on the new motor) and compression was 190 across the board, This left me scratching my head.
So I took it to our shop and did a leak down test, and result was less then 2% leak down in each hole. As I started to be concerned about the problem I took a light and shined it down the spark plug hole and looked at the top of the pistons, sure as sh1t, they are wet. BUT!!! get this, with this much fluid on the plugs and on the piston tops there is no smoke what so ever coming out of the tail pipe, I mean hell, if there is fluid on top of the pistons and on the plugs you would think that it would smoke out of the tail pipe.
So I started to watch my coolant levels for the last 2 months, watched my oil level and get this, it does not use a drop of coolant, and not a drop of oil
There is no performance problems at all, car runs like a raped ape and is harder then hell just to keep all 4 tires from breaking loose.
I started to think maybe it's the fuel I was using, so I drained the tank completely and put fresh gas in. Same crap, different day.
The fluid on the plugs have no smell to it at all, and I have antifreeze in the car as well so I would think if it was coolant then I would smell the antifreeze, but yet again, NO SMOKE AT ALL!!!
!!!????? and it's not consuming any coolant or oil..
any thoughts?????
-Jake
There is no performance problems at all, car runs like a raped ape and is harder then hell just to keep all 4 tires from breaking loose.I started to think maybe it's the fuel I was using, so I drained the tank completely and put fresh gas in. Same crap, different day.
!!!????? and it's not consuming any coolant or oil..any thoughts?????
-Jake
