auto tranny problem?
ericismyname
682
Oct 14, 2002
West Des Moines, Iowa
in my auto nt talon, when i floor it usually in 2nd gear the rpms will fly up to like 7 or 8 and change into 3rd, but while in 2nd when its flien up i am not going faster then i was before i pushed the gas down all the way. im assuming major tranny problems?
hmmm, I dont think I understand ur question. When your flooring it thru the gears. from 2nd to 3rd. It shifts at like 8. But when you punch it from 3rd. It kicks back into 2nd, but it doesnt Feal like your going any faster then when you where floring it in 3rd?
Thats called a kick back. It shouldnt Feal like ur going Faster then before. Its only for passing. Depending on how far up the RPM range you are on 3rd, Depends on if it will Kick back for passing.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
