Ecu Supply Voltage For Knock Sensor
93DE-EZ-UM
57
Mar 24, 2003
Raleigh, North Carolina
I have a 93 AWD. My knock sensor voltage read 0V. I traced for an open circuit all the way back to the ECU pin9 and the wire has good connection. I then cut the wire for of the harness going to pin 9 on the ECU and turned the ignition ON and measure the voltage there and it still read 0V and suppose to be roughly around 8 to 11V according to the manual. THe caps looks good and I went ahead and replaced it anyway and still have the hesitation and sluggishness. My idle also miss form time to time. Do you think my ECU is going bad gradually. Please help DSM experts..
Anyone have any idea? Please, if you think that your answer might not make sense, just post it here. It might give me some idea to help me figure out my problem. Thanks..
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
