Desibabu345
- 131
- Jul 12, 2003
Today I took out the throttle body to clean it. It was dirty as hell but now its spotless (use tb cleaner). Anyways, I put it back on the car and hooked everything up and when I started her up she immediately jumped to ~4k and stayed there, I let it run for a minute or two and it didnt change. I got scared so I went back and took the throttle body back out and I had messed up when putting the gasket in and the gasket broke. So just to see if it works for now I went and put the throttle body back in without a gasket (dont flame, plz read first). And then went back and started it up. It idled high 4kish and after a moment or two came down to 1500, only for a sec before jumping up to 2500, and it bounces between 1500 and 2500 forever... i let it run for a long time, i raced the engine and it returns to 1500 and bounces between 1500 and 2500. It's like it can't find idle. The other thing I realized was that when cleaning the throttle body cleaner - I sprayed it all inside the tb and didnt cover up the idle air passage - that has that sensor. But i dried it out - is that my problem? Or can just not having a gasket make it do that? I didn't mess with any other adjustments so im confused.
BTW i did disconnect the battery and let it reset, it does the same thing, when I start it up it jumpts to 3-4k and stays there for a sec or 2 and then falls down to 1500 and bounces between that and 2500. What should I do?
