Engine Temp rises at stops!! Waterpump??
  • Thread starterDeleted member 9465
  • Start date
Deleted member 9465
What the hell. I think I have a problem with my Car. It heats up at stop lights and stuff. When I start driving it again it cools down. How much is a water pump for a 420a? DO i have to remove timing belt and stuff to change it? Is it a all day thing??
Talon NTs.... I just dont know....
try changing your thermostat. I had the exact same problem, i just drained the radiator, got a new gasket and therostat and radiator/water mixture and i was good. $18 total and about 45 minutes of work.
-Brent
before the thermostat. make sure your coolant levels are ok. Mine was doing the same thing and it was just low coolant. If coolant is ok, then do a thermo and finally a waterpump
