help with ecu maybe more......
spyder3634
Aug 30, 2003
bellbrook, Ohio
ok i have a 1991 tsi awd 5 speed, at startup it idles around 2k then comes back down, as it does this the computer clicks, when the computer clicks the idle goes way down below 1k and boost gauge reads inconsistantly, sometimes it is way up above 14 and other times down below 0, the computer clicks and bogs down the engine, then the check engine light comes on and goes back off. the car runs and drives, the computer sometimes clicks and bogs the car down, the boost gauge spikes as high as it will go and then drops back to to 0. any help would be appreaciated, if you need more info about it, let me know, thanks
I have idle issues, but ive never ever heard the ecu clicking, except when the car shuts off it clicks once, if its clicking it may be hooped.
well ive been told its the caps and that they need replaced, so i think im going to try that and see if it helps any.....
