A/C Problems
DarkendSoul
63
Jun 18, 2003
I was and noticed that alot of people where having problems with thier A/C causing the car to stall when it was running. Well, before I got a chance to run some more test on the car, my battery stop holding a charge. Well, I replaced the battery and now that I did the car runs perfectly with the A/C on. Apparently the battery just wasnt handling enough load to power the A/C and the ignition. The symptoms where that when I gave the car some gas at idle and let go with the A/C on the idle wouldnt stablize on its own and if I wanted to keep it running I would have to keep playing with the gas to keep it from stalling. If you are having this problem, them I would suggest you try load testing your batter, or even slapping in a new fully charged battery. (Even though you might not want to buy one unless it fixed the problem. I would suggest just boring one that you know if new and good and has at least the amp rating that your old one has from some body.)
