KingPia
- Apr 15, 2003
I just got my star stage II turbo kit hooked on, and my boost gauge is only reading 3-4 lbs, and it feels about right. I've adjusted the screw on the wastegate to the right about 3 whole turns, and is says it suppose to be 1 lb. per 1/4 a turn. I dont know if im not turning it the right way, or if my intercooler or blow off valve is leaking causing it to run at such low boost. Hit back if you got any ideas
