13g to 14b conversion
ViruzGSX
Apr 23, 2003
I have a 1g a/t and I'm wondering what all i need to make the conversion from my broken 13g to a 14b. Can anyone help me?
Originally posted by 93_GEE_ES_EX
Its a direct bolt on,you will need the 450 injectors also,I whould port the 14b while its out.
Well not exactly.
1) Your Exhaust manifold has a smaller exit to the Turbo. You can probably leave it like that but porting is recommended to take adventage of the stronger 14b.
2) You will need new water feed and return lines with the appropriate bonjo bolts and crush washers, 14B uses bigger bonjo bolts
Note: You will need to replace all crush washers, they are one time use only
I think this is it
