drintul
- Jun 19, 2002
need help, put new timing belt on daughters 90 Talon, reassembled, started up right away, purring like a kitten for about 5 minutes, then clunk and it dies! Didn't know what happened, pulled top cover off and the new belt was way loose, disassembled again, now the cam gears show the timing marks at 12 o'clock on both instead of 3 and 9. I couldn't turn crank and realign them belt had slipped, now I have got #1 at TDC crank on mark Oil pump on mark, what do I do with cam gears, to get them back in position
