toshi128
- 462
- 1
- Jun 13, 2002
San Francisco,
California
Has anyone here got the same problem??? It's the P0120, Throttle Position sensor malfunction.
Originally posted by whitegst
I have the same problem too.Dealer told me that i need to replace the TPS, but others said that it's b/c of venting BOV to the atmosphere.
Don't know who's right/wrong...
hmm.... I thought by recirculating back would have solve the problem, but CEL still came on. Damn, don't know what to do other than driving w/ CEL on.
Originally posted by toshi128
I got an used one from a junk yard for about $25, then put it in, and still got the annoying CEL, same code. Then, recirculated the BOV, then no more CEL.
RuBiCaNT5X: In your post, you said, "I am not recirculating so I think it's bad.". which means you are venting, right? unless, if you had a typo. So, please recirculate your BOV, then see what happens. I did not get any help about that CEL, or not enough definate help to solve the problem, and I tried fixing it, and recirculating BOV was the solution for me. So, give it a try and see what happens, before you buy a new TPS sensor.
Sorry man, i might not be able to help you anymore. Since recirculating was the only solution to the TPS problem I had.
I have my bov to atmosphere as well and the ce light just came on. When I vented it to recirculate the ce light never came on.hmm, i replaced my tps and the CE light would still come on giving the same code.
for those who get this CE code, do you guys have your bov vented to the atmosphere.
because its weird. i never got a CE code until i changed my upper ic pipes and put aftermarket bov vented to the atmopshere. now, just recently i helped gotEclipsed (here on the boards) install his aftermarket bov as well. it is also vented to the atmosphere. and after that, now HE HAS THIS SAME CE CODE. toshi, your greddy type s is vented to the atmosphere as well right? and you have this same code too, and no matter what you do to fix it, it comes back on.
i dont know how this all could relate together, but all 3 of us have our bovs vented to the atmosphere and we get this code. could this be the reason why? and if so how could it mess up the tps by venting to the atmosphere? toshi, you have a greddy type s which u can easily vent back to the intake, me and james (goteclipsed) have hks ssqv and we dont got the recirculation piece to vent it back. so can you try and vent yours back to the intake and reset the code and see if it comes back on.
