eoseitz
- 148
- 1
- Jun 16, 2008
Marion,
Ohio
I have a 1990 Laser RS Turbo. I've notice lately my voltage is fluctuating. I have a voltage meter on my radar detector. I know, not real accurate, but its all I have right now.
So the voltage will drop down to around 11 volts. Sometimes even 10. Then jump to around 13.3. I've checked the tension on the alt belt. It seems fine. I've got a red top battery and a car audio battery. Even with the stereo system off the voltage will jump some. Not so bad though. And when the cooling fan kicks on the car will not want to stay running. It misses.
Could it be a bad alt? I had autozone test it and they said it was producing 67 amps. They said the alt in my car was a 70 amp. It should be a 90 amp in a turbo'd vehicle shouldn't it? How large of alts can you get for dsm's?
voltage up to 16 volts now. However, I do hear the belt making noises now. Not sure how the belt could be slipping yet its making more voltage.
. Oh well. I guess I'll have to adjust the belt.
