TeeWX98GST
- 111
- Jan 13, 2008
Cresco,
Iowa
I have just installed new injector insulators and o rings. Afterwords i tested and had NO boost leaks. Prior to this my boost gauge VAC use to say around -15 (and before the leak started itd sit at -20).. now it idles at 2,000RPM and sits at -20.. but when it drops below that idle (surges a bit) itll vac up to -15.. but I have no boost leaks. AT WOT the car runs amazing with no jerking whatsoever. But anytime I try and cruise at a steady speed, It will jerk pretty bad like I'm not giving it enough gas.. but anytime under acceleration or if the clutch is out it will NOT jerk. I don't really understand what exactly is going on. But to start here's what I know is working. If this helps at all, It killed on me once and when I went to start it it like grinded for a bit before it started up..
Injectors put back in right order - Yes
Boost Leaks - None
Spark Plugs Wires in right order - Yes
So whats going on? Thanks
Boost Leaks - None
