log @13 psi need info
SvarO
92
Aug 28, 2004
panama, Central America
Hi, I just log this tonight:
am using obdgauges, is not the best but thats what i got....
I already check my leaks with leak tester and i found a big one between the turbo and J-Pipe... that could be my issue on the log??
or what else?
I don't "feel" power on mid and high.
mods.
E316G turbo, Stage 3 clutch. 2.5" exhaust system, Front Mount Intercooler, SS Intercooler Pipes, Greddy Intake, Greddy BOV, MSD Spark Plugs 8.5mm, Exhaust Manifold Ported, Evo Fuel pump not rewired, stock inyector, not AFC.
any advice or tips would be great.
If I'm interpreting those unlabeled columns of data correctly, TPS is the 3rd column? If so, they're low. Did you floor it during the pull? Full throttle should be in the high 90s for TPS.
Did you fix the boost leaks? Don't bother looking at logs if you have big leaks. Fix the leaks and then start looking at logs. You should pressurize to 20psi then watch it drop. Should be able to hold well enough so that it drops 1psi every few seconds.
Get the TPS numbers up, fix the leaks, then log RPM, airflow, timing and front O2v (bank 1 on pocketlogger - don't know about OBDgauge.
Good luck!:thumb:
yeah was on WOT weird eh, could be a bad TPS? I change TB for a 1G one. just the tb not sensor.
am going to fix the leaks asap, thanks for the tip, I appreciated your help.
The tps could be out of align, also check and make sure when the pedal is depressed all the way that the throttle plate is all the way open. You may need to adjust the throttle cable, the adjustment would be on the back of the intake manifold.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
